Discussion topic: TNT unavailable
This message was authored by: Stev7
TNT unavailable
TNT channels are not broadcasting saying that there is NO SIGNAL !!!! This is happening 2 - 3 x per day ??? I need to speak to SKY as they promised me Refund of monies for this fault ??
Re: TNT unavailable
Please answer the following question so that your thread can be moved to the correct place, where you're more likely to get help with your query
Which Sky TV Service do you have?
  • Sky+ (Satellite box)
  • Sky Q (Satellite box)
Avatar for Stev7
Re: TNT unavailable
SKYQ Satellite Box
Re: TNT unavailable
@Stev7
So you've already reported this to Sky.
Is it no signal or no satellite signal?
Re: TNT unavailable
Hi @Stev7    You can always watch TNT Sport on Discovery+. But assuming that you mean No satellite signal rather than No signal (TV on wrong HDML input) you need to get your satellite dish realigned.
Re: TNT unavailable
TNT channels are broadcasting!
In all likelihood, your dish is slightly out of alignment and will need an engineer to put it right. TNT channels are usually the first affected by a misaligned dish.
I wouldn't have thought any refund would be paid if, indeed, the problem is as described above.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Re: TNT unavailable
If TNT wasn't broadcasting then every user with a satellite dish would be affected, and this forum would explode.
It's always much more likely that an individual box isn't receiving, which is rather different.
