Discussion topic: TNT Sports
This message was authored by: Colin220664
TNT Sports
I was wondering what's the best price you can get for adding TNT sports to my Sky account
Avatar for Colin220664
Level 0 icon
Re: TNT Sports
Nothing resolved
Re: TNT Sports
@Colin220664  How do you expect to get something resolved within 2 minutes of originally posting
you are only asking fellow customers who respond when we can
to answer your question you would have to speak to sky direct and ask if they can offer you a deal
These are the current methods for contacting Sky…
▪️call by dialling 150 (free) from either a Sky Talk landline or a Sky mobile.
Calls to Sky will start automated which may offer you the online help route (see below) or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
▪️online help via this link
https://www.sky.com/help
▪️Sky Assistant is also available at the top of sky.com/help for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
▪️Social Media You can also get in touch with Sky via the messaging services on: Facebook or Instagram (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Re: TNT Sports
The best prices I have seen in the UK for Sky Sports from Sky on Q are from £28 - £34 depending on available deals/contract length.
Unless you are happy to watch via the HBO Max app, rather than via the TV Guide, in which case you can get it for 12 months at £25.99 direct from TNT Sports (via HBO). Make sure you use the same email address as you did to activate the included HBO Max subscription.
Cheaper still is using the app with TNT Sports as an add on to an EE mobile plan.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
