Discussion topic: TNT Reception problems
This message was authored by: Schiltach
Message posted on 19 Feb 2026 04:31 PM
I have problems with TNT sports reception,near enough every single week,either it says channel is suffering problems or I have coloured all over screen
Find out more
Message posted on 19 Feb 2026 05:55 PM
Re: TNT Reception problems
Hi @Schiltach
You maybe have a slight dish alignment issue.
This will not necessarily affect all channels but just ones with the weakest signal.
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
