Discussion topic: TNT - No Satellite Signal
This message was authored by: Bri200
We have an error appearing for all TNT channels and U&Dave HD for the last few nights saying No Satellite Signal. We have rebooted Sky box a number of times, updated software, etc.
There is nothing blocking the satellite.
The error remains. What is is causing this issue?
Look forward to getting this resolved as soon as possible - there is a significant amount of sport on this weekend.
Re: TNT - No Satellite Signal
@Bri200
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for Bri200
Level 0 icon
Thanks for your help and quick response.
It sounds like we will have to get an engineer out.
