05 Aug 2024 03:52 PM
Hi, I'm having a recurring issue with my Sky Q when I pause a programme it freezes, says the channel is not transmitting. I have to switch off my TV and Sky box and reset. Nothing on Sky to help with this. When I reset, surprise, surprise, the channel I was watching is transmitting ... Any ideas please?
05 Aug 2024 04:00 PM
By a reset I assume you have rebooted.
Have you tried a Reset Settings in the Q box hidden menu.
05 Aug 2024 04:03 PM
Hi. Thanks for this. Yes to a reboot and Yes to I've used the hidden menu options. Issue still recurs. Three times in the last week so becoming very tedious
