Discussion topic: Syncing 2TV remote controls
Message posted on 01 Jun 2025 03:03 PM
I have two remote controls, one old and one new, how can I sync them as one controls volume and the other controls the on and off switch etc.
Message posted on 01 Jun 2025 03:17 PM
Re: Syncing 2TV remote controls
hi @AS_2112
It can be done but rather convoluted.
Only one can be paired in bluetooth mode (& thus Voice control) - the other(s) has to be IR only
You first pair the one you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
