Discussion topic: Switching from SKY + / SKY HD to SKY Q - some points to note
Message posted on 01 Feb 2025 11:32 AM
Re: Switching from SKY + / SKY HD to SKY Q - some points to note
Thanks. Thought that might be the case re the minibox.
Our main aerial feeds the Sky+ box RF input with a cable from the Sky+ box to the main TV (via RF output 1) and another cable to the kitchen tv (via RF output 2). I'm thinking that buying a simple 'Y' coaxial splitter will serve the same purpose that the Sky+ box is currently undertaking..
Message posted on 01 Feb 2025 04:04 PM
@Mark++H wrote:
T I'm thinking that buying a simple 'Y' coaxial splitter will serve the same purpose that the Sky+ box is currently undertaking..
Providing you have a good Freeview signal, yes. Sky+ boxes amplify the incoming signal slightly to make up for the loss of splitting it between the RF1 and 2 outputs, and you'll lose the amplification with a simple Y splitter.
There'll be no Sky channel output, obviously.
Message posted on 02 Feb 2025 10:58 AM
It's incredible frustrating. The way I look at it is like mobile phones. Why should you have to have a smart phone when all you want is a 'brick' or basic calls and texts! The implication for older people ( getting less easy for me too!) is to navigate new menus and remote controls. Keep it simple!
yes, it would be cheaper to go back to just whatever is on free channels but mum is used to how to record and watch back a planner program. She still can struggle but new menus options etc are not the way forward!!!! If you're going to introduce new tech or prevent us from upgrading / up cycling older kit - pls think about the effect of the change on ALL parts of the population!!!! GenZ may love Q and streaming but to my mum it means something very different 🤣🤣🤣🤣
Message posted on 02 Feb 2025 11:21 AM
@LP wrote:It's incredible frustrating. The way I look at it is like mobile phones. Why should you have to have a smart phone when all you want is a 'brick' or basic calls and texts! The implication for older people ( getting less easy for me too!) is to navigate new menus and remote controls. Keep it simple!
There are plenty of basic mobile phones around to just make calls, send texts. No-one is forced to purchase...
Message posted on 02 Feb 2025 01:21 PM - last edited: 02 Feb 2025 01:23 PM
The end of satellite television broadcasting, which for the UK and RoI is likely to be around the end of this decade, will be a fundamental shift for everyone, no matter what age they are.
Message posted on 02 Feb 2025 01:31 PM
yes, it would be cheaper to go back to just whatever is on free channels but mum is used to how to record and watch back a planner program. She still can struggle but new menus options etc are not the way forward!!!! If you're going to introduce new tech or prevent us from upgrading / up cycling older kit - pls think about the effect of the change on ALL parts of the population!!!! GenZ may love Q and streaming but to my mum it means something very different 🤣🤣🤣🤣There are plenty of basic mobile phones around to just make calls, send texts. No-one is forced to purchase...
Less true of ye olde SkyHD though
Message posted on 02 Feb 2025 09:23 PM
We've relatively recently migrated from Sky+ HD to Sky Q, and we've been Sky TV users for just over 30 years, back to the days when it was analog, and I'd have to say that the user interface of the Q box is NOT user friendly, and it's a lot less intuitive than the Sky + box was, it's altogether too easy to get very confused when navigating, and some of the choices are not at all intuitive, and given that Sky have now forced the issue for many users by refusing to allow Sky + boxes to be reused by allocating them to a different viewing card, that's effectively killed many of those boxes, not exactly a user friendly move.
In the longer term, the future of satellite broadcasting is not secure, the costs are just too high, and with the way that broadband distribution is going, there will be very few people who won't be able to get broadband, even if that ends up being via mobile broadband, but bandwidth availability may well be a limiting factor there.
The other downside of all of this is that the standards that Sky work to have declined, at one time, the Sky service was a premium service that justified the higher price, but things like series link not working correctly all too often, and time shift recording not working correctly because the schedule has been changed, especially annoying on the channels controlled by Sky, F1 racing being a prime example, the number of times that Ted's notebook has been missed completely is just unbelievable, and that channel is controlled by Sky, but way too often, what's recorded is a joke, and that's totally frustrating.
It's issues like these that make it tempting to abandon the service, and forget about Sky completely, given the costs involved, and in the longer term going forward, if we're not going to have satellite, and only broadband services will be the future, then that's a very different system, and Sky need to look very carefully at how that will work for them, as they will lose their advantage, they'll be just another supplier alonside a host of effectively identical options, and that will make their options a lot more limited.
What will be critical is making the entire system user friendly, and not just for the younger generations, things like having remotes that can be seen sensibly with less than optimal eyesight, or less than optimal finger motion, they're going to be important, and need to be proof tested BEFORE release, not discovered by accident after the product hits the market, as a result of complaints from people who are effectively excluded from using the new system as a result of significant shortcomings in how it's been programmed and implemented.
That may mean that there needs to be a way to manage the whole short press or long press type options, to ensure that all users can use the system, not just the select ones that don't have problems. Even things like the number of button presses to get to some options can be an issue, especially for users with things like arthritis, multiple presses to navigate can be physically challenging, because of things like painful joints, or joints that just don't respond like they used to, but all too often, those sorts of issues don't even occur to the people doing the programming, years ago, I can remember a box we had where the user initial set up option was menu item 1, and the time recording option for time shifting was number 7, but to get to it took 7 down button pushes, and the developers never changed it, despite many complaints, and that's the sort of stupidity from developers who are only interested in getting a package out of the door, rather than getting it right for the end users, initial set up was used perhaps once or twice a year, time shift was in some cases used multiple times a day.
Message posted on 10 Feb 2025 09:11 AM
Many thanks Nigel,
There is a lot of great advice in your reply if we decide to go to SkyQ but I think we'll stick to Sky+
for now and try to empty our saved programmes.
Message posted on 10 Feb 2025 11:57 AM
@Irish-Steve there is an accessible remote available. I don't know how good it is.
Message posted on 01 Apr 2025 10:35 AM
HI Nigea99
i have read your Blog 6th Dec 2023 about SKY Q box you can use a hDMI cable spillter to use another TV on the 2TB box it has 2 HDMI connections can you use one of them to feed another TV and you did mention that the BLUETooth may wotk long Distances would this work in a distance from upsatairs to having Manin TV down stairs txs
Message posted on 01 Apr 2025 01:49 PM
@fletpablo wrote:
HI Nigea99
hi @fletpablo
I am not too sure what you may be referring to as I don't have any Blogs but I guess it may have been a reply I made to someone here.
The older 2TB boxes (non HDR) that may have had 2 HDMI connections, you shoud be aware that I believe only one is output- the other in theroy being input - although I am not sure if it was implemented
Regarding Bluetooth remotes, in my experience I have found they are very good over quite a distance. I have used mine (as tests) from all my upstairs rooms & also from outside in my back garden, with my box in an alcove in my front room next to the front window - so through 2 rooms and 2 (ordinary brick) walls .
Message posted on 27 May 2025 05:35 PM
Thank you for all the information
It's good to be aware of changes
Fingers crossed we get use to sky q as we are elderly people and sometimes new technology can be confusing
Message posted on 20 Jun 2025 06:24 PM
Thank you most of that was very helpful.
Message posted on 18 Sep 2025 09:23 AM
Thanks for the very useful info.
I'm considering the Sky Q box to replace my Sky HD box. However, I've just purchased a brand new satellite dish and LNB. Had it professionally fitted by my local aerial firm. If I move to Sky Q will the sky engineer just change the LNB? Also can I retain the old (brand new) LNB?
Thanks. Willow.
Message posted on 18 Sep 2025 09:29 AM
Thanks. Willow.
hi @Willow+1000
Yes they should only need to change the LNB (assuming you have either twin cable or 2 separate cables) - they do not change a dish or cabling when they are in good condition.
They will let you keep the LNB they replace (after all it is your property) but you probably would need to make sure they aware you want it before they start work.
