4
This discussion topic has been answered Discussion topic: Switch on satellite signal
This message was authored by: Nickyvdw
i've recently moved house and I have everything connected and wired, internet sorted, dish already installed and literally just need the satellite signal to be switched on. Do I need a sky engineer to physically come to my house to do that or can this be switched on remotely?
This message was authored by: Doc5907 Answer
Re: Switch on satellite signal
@Nickyvdw wrote:
Thank you for your response. makes sense.
I have an engineer booked for the end of july ( soonest I could get) but thought I may not need this and hope d it would be more of a plug and play situation.
Cleatly not and will therefore need to wait another 2 weeks!
@Nickyvdw  if that time frame is a bit long for you, there's also the possibility of calling up a local satellite/aerial company who may be able to sort it much quicker, at a cost of course.
Sky Q 1TB UHD
LG TV
Sky Mobile
hi @Nickyvdw
Satellite TV does not need switching on like Broadband etc
If you have connected it and it is not working then it is quite possible that electronic bit on the dish (LNB) is not suitable for SKY Q & this would need to be changed by an engineer to one wo work with SKY Q
I guess it is also possible that the dish is not properly aligned which, again, would need an engineer to visit
If you don't have your own dish but a communal feed then it might be a couple of other things
BTW did you arrange the move through SKy - as they usually arrange an Engineer visit as part of that
Avatar for Nickyvdw
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: loverboi
@Nickyvdw but you can try to get sooner if you check regaly in the my sky app and where you can rebook your appointment you can check the dates as might be a earlier one like i did i got one the next day instead of waiting for 3 days time 🙂
