3
This discussion topic has been answered Discussion topic: Swapping TVs
This message was authored by: Woody33
Swapping TVs
I have swapped Samsung TVs between rooms. I cannot control the sound/on-off with one of the Sky Q remotes. I have tried re pairing but the setup returns "can't find your TV". The TV worked perfectly with the other mini box.
I have tried selecting Vetel and Other brand but none of these options work. I have also tried power failing everything.
Any ideas please?
Avatar for Woody33
This message was authored by: Woody33 Answer
Re: Swapping TVs
Thanks for your advice oldfella.
Found the issue.
My Samsung soundbar was blocking the signal to the TV!
Put the soundbar on the floor and I was then able to pair the remote.
I may have to experiment with the position of the soundbar (or maybe just ditch it).
Re: Swapping TVs
Any ideas please?
Hi @Woody33
Samsung TV should not be a problem for pairing.
Avatar for Woody33
Re: Swapping TVs
Found the issue.
This message was authored by: PeteRG41
Re: Swapping TVs
Found the issue.
I have the same kind of problem with my LG TV (the soundbar is blocking the IR signal from the remote.  I solved this by pointing the remote at the ceiling and letting the signal bounce down to the TV.
____
Pete.
