Discussion topic: Subtitles on Netflix when viewing via Sky Q.
This message was authored by: Chris.Hurren
Hi there,
Why can't I get Subtitles on when viewing Netflix via my Sky Q box. I can get them viewing Netflix direct on the smart tv. ?
from
Chris H.
This message was authored by: Invisiblename
Re: Subtitles on Netflix when viewing via Sky Q.
@Chris.Hurren wrote:
Hi there,
from
Chris H.
Assuming what you're watching offers subtitles, they're selectable from the bottom, scrollable menu - just checked it in Top Gun: Maverick.
I am just another Sky customer!
Avatar for Chris.Hurren
Thanks for your reply, however the Subtitles box says : Subtitles Off with a tick and you can't change it to Subtitles on! Even on Maverick.
Chris H.
Chris H.
Not the Sky sub menu, the Netflix app lower menu
This message was authored by: naps77
Hi just start the Netflix program, push the bottom blue down arrow and it goes to English,  then press the right blue arrow to go to English subtitles and press the middle button.  You then are subtitled. If you need to take it off then reverse what I said. We all have a hard hearing and it go to see words now. Bit the English language has changed and I understand subtitles
