12 Apr 2023 08:01 PM
Hi.
I have only noticed this today, prior to this happening I was able to select the subtitle option when I wanted it but now I have to turn the subtitles off unless I want them on which is usually when there is poor audio and I am finding it difficult to hear the dialogue clearly.
Is anyone else having this problem?
Cheers 🍻
12 Apr 2023 08:16 PM
@Mikeyboy67 wrote:
Hi.
Cheers 🍻
Hi @Mikeyboy67
To turn Subtitles off globally you need to turn them off in Home - Settings - Accessibility.
@Mikeyboy67 wrote:
Hi.
Cheers 🍻
Hi @Mikeyboy67
12 Apr 2023 08:17 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Mikeyboy67 The voice command "subtitles off" changes the default state to off.
12 Apr 2023 08:39 PM
@oldfella - yes I do know about that it's just that then when I want to enable subtitles I will have to go back into that particular menu or as @MightyQuinn says use a voice command to switch them back on.
Thanks anyway !
12 Apr 2023 08:47 PM
Thanks anyway !
Hi @Mikeyboy67
No you do not need to go back into the accessibility menu.
If you turn subtitles on using the Question mark button they will only be on for the channel you are currently watching.
12 Apr 2023 08:53 PM - last edited: 12 Apr 2023 08:54 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Mikeyboy67 The difference between the two systems is the voice command changes the default state and the "?" route only changes it temporarily.
12 Apr 2023 09:21 PM - last edited: 12 Apr 2023 09:24 PM
I just found out the problem.
For some reason subtitles in the Accessibilty menu were enabled even though I didn't change it.
I have just turned it off again and it is now how it used to be, I only have subtitles on when I want them on!
12 Apr 2023 09:25 PM
I have just turned it off again and it now how it used to be, I only have subtitles on when I want them on!
Hi @Mikeyboy67
Just bear mind that if you use voice control to turn Subtitles On or Off this changes the accessibility setting
12 May 2024 11:52 PM
Sorry @oldfella, I turned the subtitles ON usinng the Quetion Mark.
The only way I could prevent them switching on again every time I changed channel was to use a voice command.
