Discussion topic: Subscription upgrade
This message was authored by: Davefletch
I have sky sports as part of my package, it works fine on sky go,but on sky Q , I get the message. You do not subscribe to this channel press red to upgrade, when I do press the button, says you already subscribe to this channel, yet it doesn't play.. ?
Re: Subscription upgrade
Hi @Davefletch
Are you watching Sky Sports in UHD by any chance?
Avatar for Davefletch
No hd only ,
@Davefletch wrote:
No hd only ,
Exactly which channel do you have the issue with @Davefletch
Any sky sports channels except sports news
I did a system update, reconnect to router and power disconnect. Without success. Called sky spoke to advisor and after 20 mins on call was disconnected
Hi @Davefletch
Assume you have tried rebooting your Q box?
Also check your Sky Q package in your  Q box Home menu.
Scroll down to My Sky at the bottom of the menu.   See if Sky Sports is listed in your package.
Thanks for your patience old fella. Yes I have rebooted my Qbox. No change. Sky sports was working fine last week. But has suddenly stopped. My subscription lasts till 2027. And as I have mentioned, when I pressed red button to upgrade, says already subscribed.
Hi @Davefletch
You could try refreshing your viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Failing this it looks like you need to contact Sky for them to refresh at their end.
Don't know if my last message posted, if not I thanked you for your patience and help. But I'll have to wait for my wife to stop watching her programmes to try that,. I'll update you when and how I got success.
