Discussion topic: SKY Q BOX RED LIGHT ON EVERY MORNING Then goes off
This message was authored by: SusanB2
Red light comes on every morning around 10:00am. For around 20 minutes then goes off. Then works perfectly normal.
Re: SKY Q BOX RED LIGHT ON EVERY MORNING Then goes off
Hi @SusanB2
Avatar for SusanB2
Thank you so much for kindly detailing the solution. Will try to follow your instructions soon.
