3
This discussion topic has been answered Discussion topic: Subscription problems
This message was authored by: No+listings+avail
Fully subscribed including mini box. but no picture
BrucieR
Re: Subscription problems
@No+listings+avail
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
@No+listings+avail
Any error message? Have you tried a reboot…
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for No+listings+avail
Tried all of this, several times, trying to get through to SKY is like blood out of etc...I have a mini box subscription, but screen asks me if I have one??!!
Aggravating...
BrucieR
@No+listings+avail
Answered - Go to Answer
