Discussion topic: Stuck on start screen
This message was authored by: EmmaPPP
I cannot get the mini box to work on new tv - stuck on your advertising screen
Re: Stuck on start screen
A change of TV shouldn't make any difference.
Can you change the channel as they often default to the Sky channel.
@EmmaPPP Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
