Discussion topic: Stuck on awaiting tv schedule
This message was authored by: debra+farrell
My sky gets stuck on  waiting for tv schedule. I have to reboot everything about 3 times a week....Also  network disconnects about twice a week For the price I pay every month. This is not acceptable. I spend so much time turning everything off re booting  and re setting
Re: Stuck on awaiting tv schedule
Hi @debra+farrell
