Discussion topic: Stuck on Step 2 of 4
Message posted on 27 Jun 2023 03:10 PM
I have lost connectivity. I am at Step 2 of 4. The screen is saying "Go to a nearby connected Sky product and press and hold the arrows button until it flashes. But the light on this button is already flashing, and pressing it does not make anything happen.
Message posted on 27 Jun 2023 03:58 PM
Re: Stuck on Step 2 of 4
Hi @FredJK
Following a Network reset you need to press the WPS button on another connected Q device not the one connected to the TV where you get the message.
Normally when connecting a mini you need to press the WPS
button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 21 Dec 2024 12:54 PM
This isn't working for us either
