Discussion topic: Streaming channels to mini box
This message was authored by: Shazacky
Hi. Confused. Recently changed a few subscription packages. Now, our Sky mini Q box isn't getting the same channels as our main sky Q box. Examples are: History Channel, sky crime, geography channel. Available on main box downstairs but not on mini box upstairs. How do I correct this, please? Any advice?
Re: Streaming channels to mini box
Hi @Shazacky
Apart from  not showing UHD a mini will deal with the same channels as the main Q box.
First thing to do is a Software Update to make sure all boxes are on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software.
Once they are on all the same version
