4
This discussion topic has been answered Discussion topic: Starlink
This message was authored by: Charliepanda
Starlink
Why does starlink keep dropping out only when I connect to Sky q
Re: Starlink
@Charliepanda Sky Q boxes use a proprietary WiFi set up which means only the main Sky Q box connects to any router which doesnt support the system like your Starlink router.. Any Sky Q mini boxes normalky have to be networked to the main Q box not the router unless using an Ethernet cable. Sky can provide .boosters if you have Q minis that will not remain connected to the mmain Q box or in some cases can provide other solutions. .
Re: Starlink
@Charliepanda Ask starlink that?
Re: Starlink
@Charliepanda  Your post has been moved from the Broadband Board as you don't have Sky Broadband, therefore your issue is not Sky Broadband related.
Re: Starlink
Re: Starlink
Is the starlink connection completely failing or just the Q connection to it?
