This discussion topic has been answered Discussion topic: Sky Q Mini Box Disonnects Daily
Message posted on 24 Feb 2026 03:35 PM
First, The AI chatbot is so bad.
My Sky Q Mini Box connection is lost daily. I need a replacement Sky Q Mini Box.
I just need a Human to read this message and someone from Sky to Send a new Sky Q Mini Box.
I pay enough to SKY monthly.
just send a replacement
Message posted on 24 Feb 2026 03:41 PM
Hi @sdfh
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue try completely resetting your mini box.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @sdfh
To contact Sky
Re: Sky Q Mini Box Disonnects Daily
Hi @sdfh If you follow the article below, it should lead you to a box swap. Note, nobody is going to send you a replacement box on the back of a public community forum.
