Discussion topic: Sports channels not working
This message was authored by: s_rees3
Seems most of my sports channels aren't working
Re: Sports channels not working
What's the matter with them @s_rees3 ???
Avatar for s_rees3
Says there affected by satellite signal
Avatar for s_rees3
Been like it for a few days
@s_rees3
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Avatar for s_rees3
I think it needs an engineer
@s_rees3
If the link troubleshooting suggests an engineer is required give Sky a call.
