Discussion topic: Speak to advisor
This message was authored by: Gogsy123
Speak to advisor
Can't change channel  and adjust volume
Re: Speak to advisor
Hi @Gogsy123
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue,
Try completly resetting your Bluetooth remote.
This message was authored by: Gayle10
I need to speak to an advisor on how to do that
@Gayle10
How to do what? You've added to a thread made 10 months ago.
▪️I AM NOT A SKY EMPLOYEE ▪️
