Discussion topic: Soya box won’t switch on
Message posted on 25 Oct 2025 06:21 PM
About for times my skyQ box won't switch. Stays as Amber not Green. I switch off at plug and on again and it does work. But I think I have a problem with the SkyQ box.
Message posted on 25 Oct 2025 06:24 PM
Re: Soya box won’t switch on
About 4 times the SkyQ box won't go from amber to green. I've switched off at plug and got it working, but I think I have a problem with the box.
Message posted on 25 Oct 2025 09:01 PM
Hi @Stevr
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
