8
This discussion topic has been answered Discussion topic: Source mode issues
This message was authored by: Bronwen1
Source mode issues
When first switching on I often can't get connected and a message comes up unknown source mode. This has only happened since I received a new sky q box, I have done all the usual things over and over, sometimes 5 times before I can get a connection, ( switching off at mains) I have changed the connection wire after speaking to one of your advisors. This problem isn't going away, I am fed up with pretty much every other day haven't to switch off and on.
i need help with this.
This message was authored by: Chodley Answer
Re: Source mode issues
Which replacement HDMI cable did you use?
Is the box set to output 2160p / 10bit ?
Avatar for Bronwen1
I'm using the cable sky sent me, have no idea about the other thing.
You said you'd tried another cable?
Check your video settings for the other question.
Avatar for Bronwen1
Looked can't find anything.
Can't see the output resolution?
and the cable? Did Sky send a new one or something?
Avatar for Bronwen1
I'm looking in settings at system info, is this the right place.
Avatar for Bronwen1
I've phoned sky hopefully what they have told me will help, thanks for yours.
