Discussion topic: Soundbar
This message was authored by: r.seyfarth
Soundbar
How do I turn Tv volume off and play through sound bar through sky q?
Re: Soundbar
hi @r.seyfarth
Is SKY Q connected to your TV or directly to the TV ?
Have you just got SKY Q or the Sound bar  or anything else changed that you are asking ?
Depending on your answers above will depend on the next questions or advice
It would help if you can give us the both the Make & Model of both your Sound Bar & TV
Avatar for r.seyfarth
Re: Soundbar
All sorted now thank you 👍
