Discussion topic: Sound
Message posted on 06 May 2026 09:27 AM
Sound
Sound out of sync with actual TV
Message posted on 06 May 2026 09:54 AM
Re: Sound
Hi @cmsdowns
Are you using a HDMI cable directly connected between your Q box and television set?
If so, Have you tried rebooting your Q box?
If you still have the same issue, then also reboot your television set by removing the power lead and then reconnecting.
