Discussion topic: Sound
This message was authored by: Nannijan
Sound
No sound on any channels
Re: Sound
hi @Nannijan
First thing is to check that HDMI cable is propely connected at both ends
If your TV (or SOundbar) is not cable of decoding Dolby Digital, double check the setting in
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
is set to Normal
If still no joy I suggest a full power down restart of both your SKY Box & then, if still having problems. your TV:
Use the remote to place it into standby mode
 Then remove the power to it (either switch off at mains or remove the power plug)
 Wait at least 30s
 Then re-apply the power & wait for it to fully restart - this may take a few minutes.
