Discussion topic: Sound break ip
Message posted on 05 Dec 2023 12:37 PM
Sound break ip
I get get sound breK up when watching live TV and also on recordings like last night while watching the nun 2 and also a flickering happened for about 1 minute too any one 1⃣ know if the is a signal problem or not
Message posted on 05 Dec 2023 12:44 PM
Re: Sound break ip
If there was a major satellite signal issue the forum boards would be full of posts countrywide. Any error message coming up on the screen? What have you tried so far?
Message posted on 05 Dec 2023 01:07 PM
Re: Sound break ip
Jot getting an error message sound just breaks up and very occasionally picture flicks too all I do is take plug out then put it back in
Message posted on 05 Dec 2023 01:14 PM
Re: Sound break ip
Might be worth also checking the cables going to the TV in case one has worked loose.
Message posted on 05 Dec 2023 01:31 PM
Re: Sound break ip
Done all thst and when it don't absolutely fine
