Discussion topic: Some sky channels won’t work
This message was authored by: Slmbo33a
I can get all the sky channels and sky cinema on my computer but not on theTV. It comes up with an error message saying I don't subscribe to the channels I'm trying to look at. Obviously some of them it may be correct but the ones I can see on the computer I can't look at on my tv. Any ideas? TIA
Re: Some sky channels won’t work
hi @Slmbo33a
Do you have the HD add on  or if not is it possible that the channels you are trying to access are the HD versions rather than the SD ones (the default for SKY go)
