Discussion topic: Some sky channels not working
Message posted on 07 Jun 2023 09:45 PM
Message posted on 08 Jun 2023 08:16 AM
Re: Some sky channels not working
@Mike+2021 wrote:
Sky sports news and some other sports channels Have technical error showing
Hi @Mike+2021 Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Message posted on 08 Jun 2023 09:02 AM
Hi
Thanks for the reply
I've tried that and it hasn't worked
I'm wondering would the very hot weather affect the coverage
Message posted on 08 Jun 2023 09:17 AM - last edited: 08 Jun 2023 09:47 AM
@Mike+2021 Nothing to do with weather (unless it was heaving rain or snow) as the signal you get is a nationwide coverage, if the weather affected a satellite signal in this way you can bet there woud be dozens of posts/threads about it.
It is likely to either me a LNB or dish issue and you'll need to contact Sky to arrnage an engineer visit.
Message posted on 08 Jun 2023 09:44 AM
Thanks for your help, I'll contact them
