Discussion topic: Some content not downloading while others are
Message posted on 04 Mar 2023 10:34 AM
I am having trouble downloading some programmes/films to SkyQ. They get added to the queue and remain at 0%.
I have followed the recommendation on sky help of going to Recording --> Downloading and then Pause/Resume.
I have also tried with rebooting of router and Sky boxes, checked Hardware/software versions are as expected.
There doesn't seem to be router issue or connectivity. Downloading some programmes works fine but then others just get stuck at 0% and doesn't seem to be a consistent pattern.
Any suggestions?
Message posted on 04 Mar 2023 10:39 AM
Re: Some content not downloading while others are
Any suggestions?
Have you been into Recordings - Most recent and also Manage - Deleted to check that you have no failed downloads?
Any you find want completely deleting from both above sections.
Message posted on 04 Mar 2023 10:51 AM
@oldfella yes have checked both of those and nothing failed.
Message posted on 04 Mar 2023 10:55 AM
Message posted on 04 Mar 2023 10:59 AM
I had already tried the reboot and no luck. Also tried rebooting router and sky box as advised by Sky.
Message posted on 04 Mar 2023 11:01 AM
Yea, I'm not suggesting a Reboot @Wayne+Madden
I'm suggesting a Reset Settings in the Q box hidden menu
Message posted on 04 Mar 2023 11:07 AM
@oldfella @Apologies, I did mean reset as you suggested. I've already tried reset too.
Message posted on 03 Mar 2024 09:23 PM
How did you resolve this?
