Discussion topic: Some channels not working
This message was authored by: Ms+margaretgreen
Since having my sky q box I am not able to get all channels some are bbc and a few other ones I have done a self check it' says the problem is not getting a satellite sygnel
Re: Some channels not working
@Ms+margaretgreen
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
This message was authored by: Sharonw69
Quiet a few channels saying no satellite signal
Thinking off taking sky out due to issues
@Sharonw69
The advice in my previous post is the way forward. Have you followed the link? Have you arranged an engineer?
