Discussion topic: Sky q will not connect to sky router
Message posted on 13 Nov 2024 04:23 PM
I had a up grade yesterday and all was working fine this afternoon sky q is telling me that it is not connected to the sky router I have tried five times with the on screen Gide it keeps coming up not connected need sky boster I can not get any numbers off the sky q as no internet need to get some one out to look at it please
Message posted on 13 Nov 2024 04:36 PM
Re: Sky q will not connect to sky router
Hi @Murraya
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue have you completely reset your connection.
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
