Discussion topic: Software not Updating - Sky Q 2TB box
Message posted on 05 Nov 2023 12:07 AM
My Sky Q 2TB box having problems to installing software update.
Current software - Q220.000.23.00L (5Irke0s)
After downloading and installing software update from system info screen. I then put box into standby to finish installation.
When in standby blue Q light whirls round and then the box reboots but no software update and the Sky Q mini boxes keep displaying screen asking to update software.
Stuck in this loop for several days no repeating the steps with no resolution. Can anyone help?
Message posted on 05 Nov 2023 08:06 AM
Re: Software not Updating - Sky Q 2TB box
The minis don't use the Q to upgrade their own software. What happens if you upgrade them? Or are they already on 230?
Message posted on 05 Nov 2023 11:37 AM
The Q mini display the info of the main box - software version Q220.000.23.00L is is one of them which keeps intermittently displaying message to update main box.
Message posted on 05 Nov 2023 12:50 PM
Is the message definitely coming from the Sky box and not the TV? Sky boxes don't usually display messages advising of software updates other than when the software becomes corrupt (rare).
The rollout of Q23 hasn't completed yet and it wasn't on the download stream last time I checked. meaning a software update will just re-download Q22.
Message posted on 05 Nov 2023 01:12 PM
I'm still on Q220 so the new updates (Q230) are still doing the rounds and you shouldn't be able to force an update yet.
Message posted on 05 Nov 2023 01:42 PM
@xenon81 wrote:Is the message definitely coming from the Sky box and not the TV? Sky boxes don't usually display messages advising of software updates other than when the software becomes corrupt (rare).
I was going to say I've never seen a message to update.
Message posted on 05 Nov 2023 01:53 PM
@GXFIELDSMAN wrote:The Q mini display the info of the main box - software version Q220.000.23.00L is is one of them which keeps intermittently displaying message to update main box.
Can you get a photo of that message?
Message posted on 05 Nov 2023 02:48 PM
@GXFIELDSMAN I have a 2Tb box as well.
My software version is same as yours - I presume Q230 hasn't been applied to 2Tb boxes as yet
Message posted on 05 Nov 2023 02:55 PM
Yes it is the sky box, it's odd but it's what the sky mini box is doing and done it now over 3 days now and doesn't go until I try to software update the main box.
The software on the main box doesn't update, version status same. Even tried the hard roboot update where you turn box off and back on with standby button pressed to get the red and yellow flashing light and forced software update.
Problem still persists.
Message posted on 05 Nov 2023 03:06 PM
Message posted on 05 Nov 2023 04:20 PM
@GXFIELDSMAN wrote:
I don't think that means the main box
Message posted on 05 Nov 2023 04:50 PM - last edited: 05 Nov 2023 04:53 PM
Hi @GXFIELDSMAN
When you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
Software updates are released to boxes in batches and cannot be forced manually during batch release.
Although the latest is Q230..... it will not be possible to download this manually until it is on the DR stream for download and so you may find the boxes on Q220....
Not sure if Q230... has been sent to all Q boxes and if so it will be on the DR stream.
See following link for Software versions and how to check and update.
https://www.sky.com/help/articles/updating-sky-box-software
If you still have the Update message in your photo try a Reset Settings in the main Q box hidden menu.
Message posted on 05 Nov 2023 05:29 PM
According to Sky website there is no update as yet
https://www.sky.com/help/articles/sky-software-updates
Message posted on 05 Nov 2023 07:44 PM
The Software page will not updated until the latest Q 230..... relaease has been sent to all boxes.
Once this is done it will be added to the DR stream for manual update.
All as explained in my previous post immediately before your post
Message posted on 05 Nov 2023 07:49 PM
@oldfella Thank you. Do we know what the new update is about? Looking forward to it
