Discussion topic: Software issue on recordings and main screen
Message posted on 02 Apr 2024 07:33 PM
I keep having a software issue on recordings and main tv also mini boxes not working saying no connection
Message posted on 02 Apr 2024 08:22 PM
Re: Software issue on recordings and main screen
Hi @sfc1
Unfortunately Q box will erroneously report Software issue on some failed recordings.
Not normally any to do with Software.
Regarding mini connection.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
