Discussion topic: Slow downloading technical issue
This message was authored by: GAMCG
I'm trying to download a series from Sky and it's so slow the comes up there's been a technical issue?
Re: Slow downloading technical issue
@GAMCG
Is this happening on Sky Go or on another device ?
Avatar for GAMCG
On the normal Sky Q box?
also when using apps IPlayer, STV keep buffering!
the internet signal looks good
As you had posted this in the Sky Go forum I have moved this to the Sky Q one for you.
