Discussion topic: Slow Ethernet Connection To Sky Q Mini Box
This message was authored by: StuartW1
Hi,  I've recently had Sky Fibre fitted with speeds to the Sky Router showing a very respectable 500mbps.  I have two separate Cat5 cables, one running from the Sky Router to the main Sky Q Box, and the other to my Sky Q Mini Box.
Using the Netflix App on the Sky Q Main Box I can see there is a healthy 300mbps connection.  WiFi in the same room as the Sky Q Main Box is a good 250mbps.
On the Sky Q Mini Box the speed, using the Netflix App on the Sky Q Mini Box, is sub 50mbps.  WiFi in the same room as the Sky Q Mini Box is a poor 25mbps.  (An iMac connected via Ethernet to the Sky Router, in the same room as the Sky Q Mini Box, gets a very healthy 500mbps connection).
How do I increase the speed to the Sky Q Mini Box?  The poor speed means poor WiFi in that room and I think it is also resulting in the Sky Q Mini Box sound sometimes dropping for a second, especially if people are using the WiFi in that room.
Any help would be very much appreciated! 👍😀👍
