3
This discussion topic has been answered Discussion topic: Sky Q won't connect to broadband
This message was authored by: Hixsonl
Hi. My sky q box won't connect to my broadband, which it has previously been connected to for years. The router and box haven't been moved. I've reset the sky q box and the router. All my other items like laptop and phones are connected and working fine to the router. I've reset the network status and tried connecting to the router again. However it doesn't connect when I'm holding the wps button. The correct one on the side. I have also tried the option to add as a non sky router (even though it is) and it picks up my WiFi as its listed, I go in it and enter password from back of router but it then says the password is wrong. Any help would be really appreciated. Thanks
This message was authored by: Laing1 Answer
Re: Sky Q won't connect to broadband
@Hixsonl try resetting you router there should be a reset button on the router it sound like you have a SR 203 so the reset button is on the back of the router press and hold it for 20 seconds Once the router is back up and running reboot your Q main box and as you know once it ask you to press the wps button go to your router and press the WPS button
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Hixsonl
Perfect, that worked. Thank you so much, been driving me mad
@Hixsonl glad to have helped
