Discussion topic: Skyway box problem
Message posted on 11 Oct 2023 09:47 AM
Skyway box problem
Hi. I'm having trouble with the pictures on my tvs which keeps breaking up. I've just had a guy from the aerial company & he's tested the signal which is ok. He said it's the Sky's box fault. Can you send an engineer as soon as possible. Thank you
Message posted on 11 Oct 2023 09:51 AM - last edited: 11 Oct 2023 09:53 AM
Re: Skyway box problem
@SueBadger Your post and title are a bit confusing, You have posted Sky way box? Not sure what that is.
Which box setup do you have? Do you use a communal dish or your own dish?
You also can't request an engineer through a public forum.
Message posted on 11 Oct 2023 09:52 AM
Hi @SueBadger
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
