Discussion topic: Skys ratio
Message posted on 25 Aug 2024 11:01 PM
Skys ratio
I just go a projector with the ratios 4:3 and 16:9 and when using sky It's really zoomed into the top left cornor and when I use my Xbox it's perfectly fine how do I change this?
Message posted on 26 Aug 2024 07:21 AM
Re: Skys ratio
What resolution does the Q box think it's outputting, in the AV settings?
Message posted on 26 Aug 2024 11:11 AM
Re: Skys ratio
I don't know how to look at that how do you do that?
Message posted on 26 Aug 2024 11:16 AM
Re: Skys ratio
@Beeboop A guide is available here https://www.sky.com/help/home/sky-tv/sky-tv-q/using-sky-q/settings-and-preferences-q-test
