Discussion topic: No TNT GB News
Message posted on 24 Aug 2024 02:37 PM
No TNT GB News
Hello team, having problems with sky signal. Cannot get Sky sports TNT and other channels such as GB News. I have re-booted everything three times and just keep getting the following message " the channel is currently effected by a problem with your Satellite signal" can you help?
Message posted on 24 Aug 2024 02:42 PM
Re: No TNT GB News
A few people are reporting issues with signal on TNT, but otherwise check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 24 Aug 2024 02:43 PM
Re: No TNT GB News
@Roger+JD wrote:Hello team, having problems with sky signal. Cannot get Sky sports TNT and other channels such as GB News. I have re-booted everything three times and just keep getting the following message " the channel is currently effected by a problem with your Satellite signal" can you help?
Sounds like your dish may have moved in the recent winds.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 26 Aug 2024 12:43 AM
Re: No TNT GB News
Cheers, it was my dish, windy day.
Message posted on 26 Aug 2024 09:52 AM
TNT Sports
TNT Sports channels all show a no satellite signal message. Never had this problem before. All other channels are fine.
Message posted on 26 Aug 2024 11:06 AM
Re: TNT Sports
Was a solution found to this issue? I have the same problem where TNT sports and a few other channels are showing a no satellite signal screen. All other channels seem to be working fine
