Discussion topic: Skyq
This message was authored by: IssyD58
Skyq
Mini box is working but main box isn't and remote is not working either
Re: Skyq
@IssyD58 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for IssyD58
Re: Skyq
Thank you.  Tried all that. Mini box Tv is working and the main box is on but not the tv connected to the main box. Very odd! Any other ideas?
Re: Skyq
@IssyD58 just a thought is the TV on the correct HDMI input
Avatar for IssyD58
Re: Skyq
Yes thats linked. Just spoke to a tv repair man who says it's a connection between the tv and box so coming out to have a look. Thanks for your help 👍
