Discussion topic: Skyq netflix
Message posted on 03 Apr 2025 12:23 PM
Skyq netflix
Hi. I have netflix on my sky package but it does not show it on the sky apps! Any help?
Message posted on 03 Apr 2025 12:38 PM
Re: Skyq netflix
@Ashraf90 wrote:Hi. I have netflix on my sky package but it does not show it on the sky apps! Any help?
Use the Netflix app
Message posted on 03 Apr 2025 12:42 PM
Re: Skyq netflix
The netflix app is not showing under apps!
Message posted on 03 Apr 2025 01:19 PM
Re: Skyq netflix
hi @Ashraf90
To check & refresh software/apps if needed follow all the steps on this link (skipping any that are OK):
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-basic-checks
Note : The refresh of apps can take several hours before it takes place
Message posted on 03 Apr 2025 03:14 PM - last edited: 03 Apr 2025 03:14 PM
Re: Skyq netflix
@nigea99 wrote:hi @Ashraf90
@Ashraf90 or this might work. Identify something that you know is on Netflix then, using voice command "play ....." and see if that brings up the Netflix app
Message posted on 03 Apr 2025 04:49 PM
Re: Skyq netflix
While you wait for the apps refresh as mentioned in link above to repopulate.
It can take up to 24 hours.
Just use your Sky Q voice remote saying 'Netflix' that will most probably open the app, until the app has repopulated in your menus.
