Discussion topic: Skyq mini keeps losing network
This message was authored by: Ajc05
Im looking for helo before I leave sky. Every couple of days my sky q mini losing connection to the network and i have to keep resetting it and its really starting to annoy me. I dont like the fact that you can not actually phone up and someone talk you through it. Ive changed my settings on both the main box and mini to active under standy mode as previously suggested on someone elses post but still keeps doing it. Please help
Re: Skyq mini keeps losing network
Hi @Ajc05
Try a complete reset of your connection.
First carry out a Reset settings on the mini in its hidden menu.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
Then reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Avatar for Ajc05
Thank you. I will give that a try. I'm not with sky for my broadband and this has been going on for months every couple of days. The mini is in my bedroom and fed up having to constantly keep going up and downstairs to keep resetting when I want to watch tv in bed. Thank you for your help
