Discussion topic: Skyq mini box pixelation issue
This message was authored by: MandyBlx
I have 2 mini boxes both with pixelation issues the main box does not. I have sky bb. How do I obtain a booster box??
Re: Skyq mini box pixelation issue
Contact Sky @MandyBlx
Reboot the mini as above.
