Discussion topic: Hi I am due 3 sky mini boxes and only one has arrived
This message was authored by: Reds1892
Don't need pictures . It's simple . I only have received one of my 3 mini boxes I have ordered ..can you confirm the other two are on their way
Re: Hi I am due 3 sky mini boxes and only one has arrived
You'll have to ask Sky - we're other customers here and can't tell you...
@Reds1892 as @PandJ2020 says you will need to contact Sky as this is a customer to customer forum where customers help each other.
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
@Reds1892
As an aside, you probably know but just in case you don't, you can only use 2 mini boxes at the same time for Satellite/On demand content (Live channels/recordings) - although can use a 3rd if the 1st one in use is being used for a streaming app such as Netflix or DIsney+
(If you have an older 1TB non UHD box - Hardware version 32Cxxxx then this is reduced to one)
