Discussion topic: Skyq is pathetic
Message posted on 04 Dec 2023 11:43 PM
Skyq is pathetic
Skyq has no program reminder the recordings play half way through and Skyq minin box doesn't work half the time sky q is a utter waste of money
Message posted on 05 Dec 2023 12:07 AM
Re: Skyq is pathetic
Recordings shouldn't play half way through, they don't for me
Sky can give you a booster or you can use ethernet or powerlines instead of wifi to improve your mini connection.
Message posted on 05 Dec 2023 01:34 AM
Had a engineer out twice used a Ethernet cable and wps doesn't make a difference when you go to watch a recording it starts half way through the recording sky q is useless over rated that's for sure you can't even set a reminder for programs
Message posted on 05 Dec 2023 03:42 AM
Yeah we've had the reminders thing ad infinitum. We all know and most of us don't care and just use siri/hello google to quickly set a reminder.
Recordings will only start part way through if you were watching it live or on another box, I think.
If you use ethernet, turn off wifi in the installer menu or it seems to try to use it anyway.
Message posted on 05 Dec 2023 05:44 AM
If you're sat there channel hopping and actually go onto a channel you're recording at the time, your Sky Q box will automatically think you've watched the programme up til that point. Then, when you come to watch the recording it will 'continue' from the point you viewed it at. If this happens just click 'watch from the start'.
The reminder function has never been available on Sky Q and won't be added this late on in its lifetime.
Message posted on 05 Dec 2023 06:34 AM
hi @Amanda731
The others have said why recordings might start part way through.
There should be a watch from start button under the recording thumbnail. if this is the case.
Alternatively, I find the easiest way to navigate in recordings is via voice control :- handy controls are :
Skip nn minutes
Go To nn minutes
Back nn minutes
You can use hours, minutes & seconds or mix e.g. Go to 1hour 15 minutes
Skip nn minutes is very handy for adverts and you get used to the length on regular used channels (Many are around the 4 minute mark)
You can also say Go To Start
Voice control in general is very useful - see
https://www.sky.com/help/articles/sky-q-voice-control-commands
Message posted on 05 Dec 2023 07:58 AM
@Amanda731 wrote:Skyq has no program reminder the recordings play half way through and Skyq minin box doesn't work half the time sky q is a utter waste of money
Recordings don't start "half way through" unless the box thinks you are trying to continue from where you left off, which will happen if you have at anytime been on the channel that you are recording. Just look for the "watch from start button".
Message posted on 05 Dec 2023 02:25 PM
@Amanda731 I suspect you are accessing the recordings when the box has been on that channel.
You need to use the Watch from Start button
Message posted on 10 Jan 2024 02:51 PM
Re: I miss the reminder setting
- I miss the reminder setting please bring it back
Message posted on 10 Jan 2024 02:53 PM
It's never been on Sky Q so can't be brought back.
Message posted on 10 Jan 2024 03:04 PM
@plumbbob Sky Q is turning 8 next month so there is no chance of reminders being added to Sky Q
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Jan 2024 03:13 PM - last edited: 10 Jan 2024 03:15 PM
As already advised Reminders has never been on SKy Q , there is nothing to bring back
Please also note spamming the forum with the same request is a breach of forum rules, those duplicate posts have been removed.
