Discussion topic: Skycard
Message posted on 09 Dec 2023 07:33 PM
Skycard
Sky card saying not working
Message posted on 09 Dec 2023 08:06 PM - last edited: 09 Dec 2023 09:27 PM
Re: Skycard
@Lee761 what is the actual message that you are getting
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 Dec 2023 08:46 PM
Re: Skycard
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly then
Try refreshing your Viewing card as suggested by @Laing1
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
