2
This discussion topic has been answered Discussion topic: Skybox
This message was authored by: ess1
Message posted on 12 Oct 2023 02:19 PM
Have sky Q. Does "System info" show QL box details, if so where please
rgds
With my wife in a care home.
Answer
Message posted on 12 Oct 2023 03:12 PM
Thank you both for very prompt replies.. I have Q2TB 6650
Find out more
Message posted on 12 Oct 2023 02:25 PM
Re: Skybox
- Press Home on your Sky Q remote.
- Select Settings followed by System info.
- Check your Hardware version and use the table below to see which type of Sky Q box you have.
Hardware version number | Type of Sky box | Software version number | HDR-capable? | Upgrade available? |
32B0xx | Sky Q 2TB | Q220.000.23.00L | No | Yes - you can upgrade to the latest Sky Q 2TB box. |
32B1xx | Sky Q 2TB | Q220.000.23.00L | Yes | No - you're already on the latest Sky Q 2TB box. |
32B2XX | Sky Q 1TB UHD or Sky Q 2TB* | Q220.000.23.00L | Yes | Check the * information below the table. |
32Cxx | Sky Q 1TB | Q220.000.23.00L | No | Yes - you can upgrade to a Sky Q 1TB UHD Box |
32Dxx | Sky Q Mini box | Q220.000.23.00L | No | No - you already have the latest Sky Q Mini box |
*Not sure if you've got a Sky Q 1TB UHD or Sky Q 2TB box?
Check the Music section to confirm your box type:
- Scroll to Music then select Your music.
- Select Play your music using Airplay. You’ll see your box type listed (e.g. Sky Q 2TB Box2725).
Answer
