Discussion topic: Skybox won’t stay connected to broadband
Message posted on 14 Dec 2024 04:02 PM
Our skybox was set up by an engineer and worked fine with out TalkTalk internet. We have recently switched to Vodafone and now each time we switch on the box it does not stay connected to the broadband. We have to each time put in our internet password. Can you help as it's a pain to do.
Message posted on 15 Dec 2024 09:35 AM
Re: Skybox won’t stay connected to broadband
